01-19-2010, 02:33 PM   #1
Katzeye or K3 ???
Hello everyone, I wanted to know if it's worth,
to replace my focuscreen K3, with a Katzeye w / optibride.
I wanted to try the Katzeye, hoping it will not obscure my K3, in low light, or closing the diaphragm type f/6-8.
Maybe also improves the measurement spot
Thanks
01-20-2010, 07:57 AM   #2
Hi,
Are you saying that you have a k3 screen, you are experiencing darkening when stop down to f6-8 so you are unable to focus? are you also experiencing metering with the k3?
thanks
01-20-2010, 01:56 PM   #3
QuoteOriginally posted by slow2focus Quote
Hi,
thanks
Hello and thanks for your interest.
The K3 is wrong only in spots, but recalculation, measured in "center-weighted and spot rimpostando the time.
Sure, I thought the Katzeye is better, and less than obscure K3
01-26-2010, 09:06 AM   #4
deejjjaaaa's Avatar
QuoteOriginally posted by bollicina31 Quote
Thanks
1) so called "optibrite" is not being applied to split prism area.
2) katzeye is cut from K3 blanks.
3) K3 has matted (more finer matte than the rest of the screen outside of the microprism collar) prisms (that is what katzeye calls “Plus” - they just cut the screens out of K3 blanks, that's it... K3 already has matted prisms).
so if you want a variety of gridlines and/or "optibrite" outside of the microprism collar - go for katzeye, otherwise K3 is katzeye (or rather katzeye is K3).
01-26-2010, 12:09 PM   #5
QuoteOriginally posted by deejjjaaaa Quote
Thank you, very kind, explained to me the thing ...
From what I understand K3 and Katzeye, have much in common
and Optibrite, does nothing to lighten the area of microprism.
Said well?
thanks for your kind reply.
Hello
simon
01-26-2010, 12:39 PM   #6
deejjjaaaa's Avatar
so if you want to improve the central spot metering katzeye will not help you over something else also cut from Nikon K3 focusing screen (unless you will suffer a case of placebo over the expensive screen)... however focusingscreen.com has other options available for screens w/o split prism in the center...
01-26-2010, 01:51 PM   #7
Thank you for your kind response.
thought to myself a different model
without microprism on focusingscreen.com hi seen other options w / o split prism in the center
In the end, because I never tried other splitscreen, what changes have the microprism, and not have them??
Without spot metering is more accurate??
Excuse the many questions, but use manual focus lenses a lot, so I need to have the focus, precise, fast, and not obscure easily.
Simon
01-26-2010, 02:51 PM   #8
deejjjaaaa's Avatar
look at this chart
deejjjaaaa: Pentax Focusing Screens
01-28-2010, 11:49 AM   #9
The graph shows for each type of lens
The model to use splitscreen right??
Gets a bit of effort and read, but is comfortable.
Thanks
k3, katzeye, tripod
Bigma and Katzeye MichaelRD Pentax SLR Lens Discussion 4 01-23-2010 10:22 AM
K3 focusingscreen vs katzeye JohnBee Pentax DSLR Discussion 5 12-04-2009 02:50 PM
KatzEye on the K20? FHPhotographer Pentax DSLR Discussion 13 08-06-2009 03:01 PM
For Sale - Sold: Katzeye ivoire Sold Items 5 07-07-2009 11:28 PM
Question about Katzeye sinus007 Pentax DSLR Discussion 6 01-28-2009 11:31 AM
All times are GMT -7. The time now is 11:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
