02-01-2010, 07:41 AM   #31
Ratmagiclady's Avatar
QuoteOriginally posted by Jasvox Quote
Yes, it works, but in the real world when I am shooting, I would love to drop the tripod legs, level in a jiffy and catch that shot before it escapes me...the less tinkering the better.
Jason
Well, there are some tripods which have the catches for the legs at the top, rather than lower down, which might help make things go faster: basically, hold it by the column as plumb as you can, then release legs and lock them where they land... My antique 'beater' tripod has a design like that, (Nothing to write home about as a tripod, but kind of retro-gadget cool. ) but I noticed someone has a similar concept, more advanced, in something more current.
I think how it worked is that a little tug will make the legs extend, and you have to push the releases to shorten them.
It may have been Benbo again (not Benro.) It did catch my attention, a week or two ago, when I was poking around, as such a mechanism could save me a lot of stooping.
No, wait, not Benbo: found it in my browser history: http://www.bhphotovideo.com/c/product/336188-REG/Manfrotto_458B_458B_NeoTec_....html#features
Manfrotto 458B Neotech.
02-01-2010, 06:16 PM   #32
QuoteOriginally posted by Ben_Edict Quote
QuoteOriginally posted by song_hm Quote
FYI. Feisol can be fitted with a leveling base, although it is not self adjusting.
Any tripod can be fitted out with a levelling base, for example the Manfrotto ones ( tripods, heads, monopods, light stands, camera supports, lighting supports, professional tripod 338 - LEVELLING BASE ). A levelling bowl is ofcourse more convenient to use and (depending on the size) more stable, than a levelling base.
Ben
That's not quite the same as the Feisol CT-3372-3472LV shown below. The leveling base is part of the tripod base, with the center column itself mounted on the leveling base.
For the OP, if you attach some weight on the center column hook, and leave the leveling base free floating (i.e. unlocked), it must be heavy enough to self level by the weight alone. If you are really interested, ask Kerry at reallybigcameras.com, he is the US distributor for Feisol and is usually very helpful.
04-05-2010, 06:23 AM   #33
Is there then a hook at the end?
Looking at pictures at FEISOL Technology Corporation , there seems to be no hook at the end/bottom of the handle?
/Lars
04-05-2010, 02:05 PM   #34
QuoteOriginally posted by Lars Quote
/Lars
The pictures on the CT-3372/CT-3472 are cropped to show only the self leveling base. The hook is screwed on, not all page shows it attached. You can see one on the CT-3371 page display of the center column kit.
04-05-2010, 02:22 PM   #35
Which one?
I looked at this one one page you linked to:
There is a hook on the optional center column, but I do not think you can use that one for leveling! (Or is the "handle" in the leveling column replaceable?)
/Lars
04-05-2010, 07:24 PM   #36
/Lars
You are looking at the optional leveling base for the CT-3371/CT-3471. That handle is not replaceable, it is meant to be used sans center column. I don't think it accept the hook either. The picture I was referring to is the one below it marked CT-3371 CCKit, it shows the hook attached under the center column.
My understanding is the CT-3372 comes with a built-in leveling base. From post #32, notice the circular top is shown raised at the rear left, in the middle of the circular top is the leveler adjusted so that the center column is straight vertical.
04-07-2010, 04:46 PM   #37
PEG Moderator
Kerrowdown's Avatar
I've been a Benbo (name comes from the Bent Bolt mechanism used for locking it) user for 30 years plus and still using the same one. As already mentioned I believe it was derived from a WW1 machine gun tripod mounting. I'm pleased to say is never let me down in any situation in terms of its flexible usage.
The trick is not to slacken the bolt to much and as you put it down it does find it's own level of sorts.
Just use a ball head on top (mines a Benbo with revolving base added) and away you go with the fine adjustment.
04-07-2010, 06:32 PM   #38
omega leader's Avatar
We have two self leveling tripods at work, massive things for theodolites, now they have to be 25 years old, and I don't want to imagine what they cost.
All total stations for the last say 15 years have self leveled. But that is the march of time, and now no-one uses them.
I'd say your best bet would be to look for a self leveling laser and see if you could adapt the baseplate.
04-07-2010, 07:45 PM   #39
QuoteOriginally posted by kerrowdown Quote
+999!
I use both the original Kennet Engineering Trekker and Benbo Trekker II, with ballhead and pistol-grip ballhead, for 35mm and 6x7. The lower leg sections are WATERPROOF; flopping down in a creek, no problem.
self, tripod
For Sale - Sold: Slik 813 CF II carbon fiber tripod + tripod head (Australia) Edvinas Sold Items 5 08-02-2009 04:56 PM
Small Bigma Tripod Collar and Tripod Mount ? wll Pentax SLR Lens Discussion 0 07-25-2009 08:46 AM
what's the difference between a cam tripod and umbrella/flash tripod? mike.hiran Flashes, Lighting, and Studio 11 06-23-2009 06:56 PM
leveling off... dresden_phoenix Photographic Technique 11 08-05-2008 11:53 AM
All times are GMT -7. The time now is 11:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
