Originally posted by ricstew Ok lets see if I got this.........
I can buy any flash (preferably ones that allow me to reduce the flash power with a button on the back)
Yes
Quote: Put a transmitor on the camera that can handle the highest voltage of the flashes.
The voltage is important for the receivers, not the transmitter.
Quote: Put receivers on the flashes ( as many as I need )
Yes
Quote: Put the camera ( KM ) into wireless?
No. Wireless on the camera is for Pentax flashes that can talk to each other. As long as you shutter speed is 1/180 or slower, the camera will trigger the transmitter.
Quote: Put it all in manual and fire away?
Yes.
Quote: sooooo to use a slave set up........I put a flash on the camera as the main flash ( it must be able to set off slaves? How do I know that?)
If you are using optical slaves, either the flash (some have an optical trigger built in) or an optical trigger will be able to fire the slaves when the main light fires.
Quote: Use as many slave flashes as I need.......
Yes.
Quote: Put the camera ( KM ) into wireless and fire away?
If you are using basic optical triggers, no. They will fire when they see the light from the main flash. If you are using PTTL flashes, then yes.
Quote: I sooo wish my dad was alive to see how this all works. He would have had a ball!
cheers
Jan
