When I bought my K-x with the 55-300, I wanted a bag to carry just the bare necessities…camera lens, batteries, filters, lens wipes, remote trigger…and not much else. I wanted something small, but I also wanted quick access, and I also wanted to be able to put the camera away with either lens. After lots of careful measuring, I decided on the Tamrac Express 6.
You can see the bags specs here…
Tamrac - Model 3536 - Express 6 Camera Bag
Here’s a look at the front. There's a zippered pocket that's perfect for the lens cap…
Here’s a look at the back, along with the only things that fit inside…My K-x with one lens attached, an additional lens, and a Totes Micro umbrella. There's a zippered pocket for something flat, like a notepad.
The bag comes with two dividers, which also hold up the camera. There are also two shelves that can be used to keep a short lens from dropping to the bottom.
Personally, I thought those shelves were a joke. So not only do I not use them, but inside the bag I removed all the Velcro used to support them. That actually gave me back a bit of space…6 pieces of Velcro are about 1/2” thick. I removed the Velcro from the dividers, and in this next shot you can see the stitching at the locations where I removed the Velcro…
When you first start working with the dividers, it seems impossible to position them correctly…and it is. I ended up wrapping the divider in a piece of paper, positioning it, then sliding the paper out.
Here’s the bag with two dividers, a lens, and an umbrella. There’s just barely enough room for the camera lens. You can see the stitching from the missing Velcro on the dividers.
Here’s the camera in the bag. The camera sits very high…basically right at the top. I like that because it makes it very easy to pull the camera out with one hand. But others have noted concerned about the camera spilling out should the bag tip over. Now, the camera with lens in this bag is like an iceberg in the sea…you see the top but there’s a lot more underneath. There’s no way the camera will “spill out” of the bag because the lens is helping to hold it in place.
I bought a small tabletop tripod that can also be attached to poles or branches. I was hoping to fit it in the bag, but that wasn’t happening (hence the umbrella.) But surprisingly it was a perfect fit in (what everyone considers to be) this absolutely useless looking pocket on the side of the bag.
The bag has a cross shoulder strap that’s nice and long, so it sits comfortably low at my side. I can change lenses quickly and without having to stop at a bench or other flat surface. If you want to carry a flash, or have a slightly larger camera, I would definitely recommend going with the larger version. But for carrying the K-x kit and not much else…it’s about as perfect as it gets. The bag is lightweight but very well constructed. When carrying it I don't feel like I have to "baby" the bag at all...it give me the confidence to not worry about bumping the bag when walking through doorways. If I were to make this decision again, I would buy it again. Recommended.
I bought the bag from Amazon for 40 bucks, and there are many comments from owners there as well.
