Hi sholtzma,
I have the same model, but from a different production run, as mine had a single screw holding the plug in -- without any adhesive. The plug is too soft an alloy, and should have been mfg'd to a tighter tolerance, then welded in and ground square -- but it wasn't, so it loosened up, allowing a head to move, no matter how tightly it was attached to the camera platform.
I use this tripod with a Manfrotto 468 MG head with a Wimberley QR conversion clamp and a Wimberley Sidekick for my 300/2.8s and heavier lenses, so there's a lot of stress put on this setup. I tried glue and epoxy, but both loosened up in a few uses. I tried peening the column with a center punch to tighten the fit of the plug, but that also loosened up with surprisingly little use.
My final "no more playing around" solution was to drill two holes through the column and into the plug, countersink the holes, and tap them to 4-40 (got the drill and tap set from Sears). I installed two screws with Loctite, then peened the edges of the screw heads to make doubly sure they wouldn't back out. This lasted the whole last season with almost everyday use, and is still rock solid with no additional attention needed. I don't anticipate any more issues with this in the future.
Too bad they scrimped on such an important point in this product. I also won a CF 94 from them, and this was never an issue, so I guess this is model specific -- but I'm not really complaining -- It's really hard to bitch about a CF tripod that's very solid and taller than I need for under $100 USD. . . I expected to have to make a few mods to make it more usable -- and this wasn't all that difficult nor expensive (but it was frustrating and a PIA
Scott
