Tired of heavier tripods, and needing one that could fit into today's highly restrictive baggage allowances, I purchased a Slik Sprint Pro II three weeks ago, from a UK supplier through eBay.
While it was difficult to get official info on this tripod, retailers like Microglobe provide a
run-down. But not all the info is correct. For instance I can be pretty sure this tripod will not bear a weight of 63.78 lbs!
It is certainly a popular enough model to have garnered a good number of mentions and even some more comprehensive
reviews.
And of course Pentax Forums came to the rescue. Steve from Vancouver provided the impetus for a
nice thread on the tripod in January 2009. He liked it but decided to return it as it was not sturdy enough to bear the weight of his system.
Note that this tripod has improved over the years. Earlier models did not come with a
quick-release plate on the head, which would be a serious downer. Also, until recently the legs did not have foam padding at the top.
One thing I have never seen noted, so
let me be the first to say it: this tripod is available with two different heads! Everyone seems to get the ball head, model SBH-100DQ, but instead I purchased a three-way head. One knob loosens to change rotation and pitch. The other controls yaw. Thing is, I'm pretty confident that this head would bear more weight than a cheap little ball head. I don't use huge lenses, but I have no problem trusting my K20D on this.
In fact, let me try the Vivitar 105/2.5. That's a honkin' big lens for me. Certainly as big as any I would take travelling. Yep, steady as a rock.
In fact I am totally
impressed by the build of this thing for the price. I paid
70 pounds sterling since I didn't want the ball head and could find only one vendor with this specific head. Otherwise I could have got away paying ten quid less. For that price I cannot imagine a better built item. But please do not start comparing it with a 300 or 500 pound professional unit! Those would be a lot bulkier anyway.
The
legs lock at different angles and the mechanism is very cool. It took me a moment to understand and then I was blown away by the elegant design solution. Just remember to push the leg in slightly, pop up the tab to the next position, then pull the leg out until it clicks.
The
centre column is reversible by the simple expedient of unscrewing it and attaching the pieces back in upside down. Great for those macros!
The leg clasps are easy to use, unlike the monsters on my Manfrotto monopod.
It even came with a camera bag, though that is made useless by a too-small strap.
Highly recommended! But even so, I have just decided never to take a tripod on another holiday. That's what God gave us shake reduction for!
