Originally posted by bayareahdv Pasted from Post #
21 in
K-x eats AA batteries??
Here's a bit of an explanation.
Pentax dSLRs using AA batteries all have a common family trait of being fussy with batteries -
due to momentary high current drain (up to 1.484 Amps) and using voltage level threshold (cut-off at 1.15V).
When there is current demand the battery's voltage drops - the higher the current demand the more the voltage level drops.
eg: the K200D will shutdown at 1.15V per battery = 4.6V total (see post #
25 in
K200D Battery Meter Problem )
remember also even if a single battery is low (at higher current drain/demand) - it could cause the whole set to fail.
Here's a graphical illustration using that 1.15V voltage threshold (horizontal line in red)
(NOTE: to be fair - the horizontal scale in this animated comparison are not the same for the higher capacity NiMH, their ranges are wider (better) )
Since the max current demand seemed to be tested at about 1.484Amps the critical curve would be somewhere between the
2Amp curve (dark green) and the
1Amp (purple).
The eneloop shows more curves above the
1.15V red-line than the 2 well known higher capacity NiMH, and if one cares to look at the curves in
NiMh Battery Shoot Out - the eneloop maintains noticeably higher voltages than any other NiMH battery LSD or otherwise.
This is the reason why the majority consensus here whenever AA battery problems are mentioned that then knowledgeable will recommend eneloops.
I use eneloops in my K100D and K-x and I get about 1,000 shots on the K100D and over 1,100 shots on the K-x per charge, and often the camera(s) will be unused for weeks, then I will shoot hundreds of shots in a session -
eneloops have served me well.
EDIT to ADD
For the more technically minded - this is how to test the viability of any AA battery to be used in a Pentax dSLR.
There is a big difference between load and no-load voltages -
when the batteries are in use in the camera they are under load, and the voltage can be quite a bit lower than the open-circuit voltage when the batteries are under no-load.
Pentax dSLR can be quite demanding on current -
ie: the load can be pretty high.
Check out Post #
23 in
K200D Battery Meter Problem (mentioned above)
where dmessing measured actual voltage and current draw of his K200D in operation.
Basically the K200D draws 1.296 Amps at start up, and the peak current demand is 1.480A.
The threshold voltage for the K200D was 4.59V total (~=1.15V per cell if they are exactly matched)
I would think other Pentax dSLRs are going to be very similar, if not the same.
So to test the viability of your cells - use a resistor load of 1 ohm (and at least 3watt rating) - which would draw in theory 1.5A for alkalines and 1.2A for NiMH, and approx 1.65A for lithium AA - this is close enough to the start-up and perhaps the max current draws.
Under this load measure the battery voltage, if the cell is below 1.15V then it probably is not capable of powering up the K200D (or if in series the other cells will have to compensate/support it).
Use only cells that pass this criteria with a good margin, and see if the camera behaves any better.
