Originally posted by Oddity96 ouch i think i blew a blood vessel in my head lol. from the info i have gathered eneloop are the battery of choice and only by a charger that can do individual cell. think i will probably get the Maha C9000
Good choices -
For those who are still technically minded and have not yet blown a blood vessel...
If one has the wonderful Maha C9000 charger -
a much easier way to check the viability of any NiMH battery -
is to use the discharge function on a
recently and fully charged battery -
set the discharge rate to 1300mA and look at the voltage reported -
it should be quite a bit above 1.15V -
if not the battery probably won't even power up the camera.
If that passes - remove the battery, wait a few moments and re-insert it
now set a discharge current of 1500 mA - and check the voltage -
again it should be a good margin above 1.15V.
To check how long the battery is likely to last compared to another is to leave that battery discharging at the 1500mA rate and see how long it takes before the voltage drops below 1.15V - this time is not how long the battery will last in the Pentax dSLR - but it is useful to compare with another NiMH battery - eg: eneloop vs. any other NiMH - one will be quite surprised how much more quickly a typical older regular NiMH will drop below 1.15V than an eneloop -
that's the reason why eneloops last longer in the Pentax dSLR than even regular NiMH that have much higher capacities >= 2500mAh....
because eneloops have better voltage maintenance under load.
Do I have to call the emergency room for burst blood vessels?
