Originally posted by wildman I use a setup like this. It's dead solid, rigid and stable and very versatile in how you set it up. The use of a cranked column is particularly useful for macro work. It's made out of bits and pieces from the Manfrotto catalog.
But it's not for everyone. Heavy. I use it for shots for the University arboretum where they want dead sharp shots with a deep FOV and don't allow you to disturb the plant beds. So I have to shot at slow F stops. Might be a chore lugging it around in the brush though.
Next to a 055xPro
Wildman,
thanks for the info. i did some checking on the Manfrotto site, and as wildman has said they have this horizontal bar called a side arm, 131D or 131DB(for black), that will attach to the 3/8" post of my existing Manfrotto tripod (or anyone's tripod with a 3/8" thread).
BH wants $79 for this lateral side arm :
Manfrotto | 131D Lateral Side Arm for Tripods (Black) | 131DB
This side arm is not light, 2.6 lbs which doubles the weight of my existing tripod. It says it will accomodate 2 cameras mounted at the same time - not what i need of course, but one could attach a counter weight to the second mounting plate or a flash if one was working inside.
Manfrotto is obviously a professional oriented photo supply manufacturer, which is great, the accessories are available through BH Photo, but they aren't cheap.
Looks like to me that wildman has mounted the side arm off another tripod head or bracket from Manfrotto, to achieve what Giottos has done with a much simpler tripod assembly. I don't doubt that Manfrotto is busy as we write to come up with a competitive reply :-)
Anway, now i'm faced with the decision of whether to invest more into my existing tripod or buy into the Giottos tripod and have a more portable solution. Nice to have options though.
