Originally posted by philippe Actually, what I wanted was to have the 622 work on a K20d almost like the AF 540FGZ, at least have a TTL metering/steering just like on the LX. It’s a pity to condemn a good working unit to sit on shelve for ever more…
Particularly that the 622 can be transformed in to a bear bulb!
No way. Only the istD/istDS/istDS" Pentax DSLRs supported the old TTL flash control. And the PT-2D adapter does not support the current P-TTL technology. But you can still use the hot shoe to connect the flash to the camera and may be (I haven't tried that) get at least the flash-ready signal in the viewfinder. At least some older TTL-flashes work like that. Maybe it can even set the X-sync shutter speed on camera? (Metz flash can do that, even if from pre-P-TTL days.)
Ben
