Originally posted by Ed n Georgia I
What if, while using the wireless triggers, I use 1/180s instead of the recommended 1/125s???? What would happen???
If you're using more than one strobe with each at a different intensity, do you measure for proper exposure using only one of the strobes? Or, when using two, does the higher intensity stobe set the shot?
You'll get a black band or an all black frame. Any decent trigger syncs at 1/180 and most will go up to 1/250 unless you get some cheapy crap one
For the 2nd, you meter individually depending on what ratio you want and then do a meter of all to set exposure on your camera...
