OK, folks, thanks for the excellent advice. It's now clear that my cost estimate was too low, and that a stereo microscope for high-quality photomicrography is more like $2300, rather than $1000 (new). Haven't yet decided whether to venture into that range. (Used is not an option for me.)
If/when I get one, I'll update this thread with first-hand discoveries. Until then, here's what I've found:
Originally posted by infosyn 1) Would it be better to use a specialized digital camera with the stereo microscope, instead of trying to mount a K-7 on it?
Sounds like using a 14MP sensor on a stereo microscope is serious over-kill, but I already have the K-7, so the added cost would be just for the adapters, which are around $300. I expect that K-7 firmware features such as HDR, video, and auto interval shutter could be very useful, so I'll go that route to begin with. I don't see that the specialized cameras offer anything that the K-7 doesn't.
Apparently there are ways to mount a P&S digicam on a stereo microscope and still use the digicam's lens (focussed on infinity); I did not investigate this route. To use a DSLR, obviously, you need to remove the camera lens, thereby losing all auto-focus and aperture control.
All the special cameras are lower resolution than the K-7, some MUCH lower, even the expensive ones. Also, apparently some of the special cameras require a USB-tethered computer running Windows software, which for me would be unacceptable. YMMV.
Originally posted by infosyn 2) Is a "trinocular" model the best way to mount a camera?
Consensus is, trinocular is very convenient and certainly worthwhile. Incidentally, some of the Meiji scopes toggle (via prism) between the left eyepiece and the camera, while on other Meijis all three ports are always enabled (beam splitter) so you can watch through both eyepieces at the same time you take photos -- very handy although you sacrifice some brightness thereby.
Originally posted by infosyn 3) Any recommendations on brand of stereo microscope to get?
There's clearly a huge gap in image quality between $300 Celestrons and $500 Omanos, and $2000 Meijis. There's apparently NOT much difference between a $2000 Meiji and a $5000 Leica these days, which is why the extensive Meiji stereo microscope line is the real workhorse.
Originally posted by infosyn 4) Any recommendations on a source for the stereo microscope or the adapters?
Surprisingly, B&H doesn't sell microscopes. Adorama and Amazon have only stuff in the $300 range. For the decent stuff, you'll need to go elsewhere.
Meijis are available from some 200 dealers around the world. Most of the dealers in the US do not keep a full selection in stock, since the scopes are so expensive, so you can't expect to walk in and try out several models, and anything you order would simply be drop-shipped to you from the Meiji USA importer in San Francisco.
Meiji scopes are not available at retail directly from Meiji USA, although you can get an hour of very credible pre-purchase advice over the phone, and extensive technical support from them. As you would expect, without competition from Amazon/B&H/Adorama, dealer prices are only 10% or so below list price.
