Hi!
I'm bidding on
this teleconverter (Ricoh 2x Macro Focusing Teleconverter Pentax KA Mount), but received a message from the seller that states:
"Hi,
This information is regarding the Ricoh 2X macro teleconverter that you currently have the highest bid.
I was informed by an eBayer that this converter only supports program modes on Ricoh bodies. Unfortunately I can not change the description or title any more. If you already have bid on the item, you can either ask me to remove your bid, or you can retract the bid yourself. My sincere apologies for the mis-information.
Yu-Lin"
Should I retract my bid?
Thanks
Deni
