Originally posted by luma
I have been using SLR cameras with various lenses for at least past 35 years and in the “good old times” there was a rule that you should keep a “protective” UV or skylight filter on every lens, which I did religiously to this day.
I just bought a 52mm CPL filter for my Pentax kit lenses and started thinking if it is a good idea to have the two filters, UV and CPL on top of each other. So, I did some reading on the web, and it looks like few people do not recommend the use of “protective” filters at all, apparently they can have a deteriorating effect on the lens performance.
Is there any consensus on this forum regarding a general use of the protective (UV, skylight and similar) filters? Would you combine the polarizer and UV filters together? Thanks.
There is no consencus.
It is clear, that any additional glass in front of the lens will degrade image quality. The question is, whether this degradation is visible in the final image. And in my experience it is not, if you use high quality filters.
Nevertheless, there are some shooting conditions under which I always remove filters. Especially when shooting into lights (may it be natural sun light or artificial light sources), all filters I have used so far (B+W, Hoya Pro 1 mainly) lead to a visible increase in flareing and ghosting and decrease contrast and saturation.
In any case, a skylight filter is obsolete, as its slight reddish tint was used in film days, to give a more pleasing, warmer colour. That isn't needed with digital and would be countered by White Balance anyway.
Then there is your question about stacking a UV and a CPL. That is wholly detrimental. Filters should only be stacked as a last ressort, as you will add even more reflections between the different filter glasses. The CPL alone already consists of two glass plates!
I recommend protective filters mainly if you shoot under severe environmental conditions (salt water spray at the beach, windy and sandy conditions, mainly) or when there is a real mechanical hazard for the lens (rock climbing for instance). In almost all circumstances a good lens hood (aka one, that is not too short), will afford at least as much protection for the front element of the lens.
Ben
