Originally posted by mickeyobe I am very leery about the Lenspen.
To use the same cleaning surface over and over again without any means of cleaning it is inviting trouble. It might pick up some grit and scratch the lens.
To me it seems to have a rather hard surface to be rubbing on a lens.
I prefer a soft lens brush and then, only if necessary a microfiber cloth preceded with a misting by breathing on the lens.
Mickey
I second this. Breathing on the lens and wiping with microfiber cloth is the best cleaning method for any lenses or filter. no chemicals, no fancy pens to use, and works perfect. Make sure you blow and brush away any dust off the glass before cleaning.
