Originally posted by BethC I was thinking more about a situation that happened to me, I was doing pictures for someone else (Building my portfolio) at a local park, while the child was running around, from under one tree, to open shade from a building, to full sun etc....I try to get it right in camera with very little editing to do when editing a shoot for someone else. When I came home I noticed some color issues on some becuase i never changed the WB each time the toddler moved from one location to the next. I shot in RAW and adjusted them all for the Momma before she saw them, I was just curious if this would save any editing time.
Guess the concensus is it's not worth the money, so I'll just keep doing it the old way.
Have you tried the auto-white balance, for this, by the way? Trying to set manually can end up just producing more errors than it's worth, I should think.
Toddlers just plain move fast: one thing you may consider, actually, is to just use that little pop-up flash (cranked all the way down with camera exposure on manual) or a bigger one similarly configured.
In days of 'daylight film,' I wasn't screwing correction filters on all the time: (a little more latitude for 'WB' exists there, anyway, especially with negative film) ....I'd just like to put a little little bit of fill in, ...just with that little 'splash' of direct flash, (This is very different from trying to light the whole space with the most diffuse flash possible: even if the flash is aiming for four stops under, you're just easing shadows and not-coincidentally, knocking down any odd colors you might see in a sun-to-shade situation.
Balance and balance.
