Originally posted by Douglas_of_Sweden Pentaxor, looks better than I dared to hope.
Currently a copy of the
Canon FD 200mm f4 macro lens is on its way to me. Got it for a rediculously low price. Two different adapters are on its way. I plan to test them and take out the glass from the loser to get a macro-only-adapter as an alternative. Seen Canon FD to Nikon F glass-less macro only adapters, but non for Pentax. But both glass versions are quite inexpensive. Recon a version with no glass will mean no IQ loss at all and even somewhat less close focus range and somewhat more than 1:1 macro. Only vorry is how dark it will be to work with it closed down to at least f8 to get some DOF, or how slow it will be to focus wide open and then close down. After all, long macro lenses are for bugs... But all in all, this is a fairly inexpensive experiment. If now just someone could borrow/donate me a SMC Pentax-A* 200 macro, and I could have an interresting shoot out!
hi Douglas, that's a great find and I wouldn't mind guessing if you were able to get it for only $20 bucks.
what is the difference between the 2 adapters that you bought?
anyway, I did another test with the adapter again with and w/o the correction glass element. mind you that this is still only a secondary phase testing and not yet 100%. what I noticed is that the center sharpness is somehow retained at an extent even with the correction element installed. I was able to shoot some birds at infinity, thus making the lens have a focal length equivalent of 193mm. however I lose a stop of light making it somehow a 200/f3.5 glass by my estimation.
now here is an interesting test that I saw, I tried shooting the lens w/o the correction elements and focused at infinity and shoot the lens w/ the correction glass on at an approx focus range that will display atleast an equal size of the center subject in focus and equal FOV size as well.
the lens without the correction optics, has a much shallower DOF and the one without the optics has a much deeper DOF and more in focus or slightly defined background but loss a stop of light as well. also the one with the correction optics seems a bit more sharper (f/3.5 sharpness rendering equivalent).
I would say that it works both ways. with and without the correction optics for macro use. of course, expect some magnification, less FOV and loss of light and some tiny oof circles caused by the correction optics but deeper DOF.
anyway, I'm hoping that Samsung would release a better camera than the NX10, since the FD lenses seems to be a perfect fit for the NX system, which would only require a glassless adapter that could focus to infinity and obtain a much wider FOV due to the system being an APS-C dslr. much better than the M4/3 cropped cameras. I'm not sure though if they would make an adapter for the Sony NEX system.
I'm keeping that one in check til the end of the year, whether Samsung will have an upgrade or Pentax would release a new system that would fit the FD lenses perfectly. APS-C is ok but FF would be great. I believe the mirrorless concept made this possible, so let's hope so. atleast we can now use some old and cheap FD glasses on new mounted systems. only problem, some systems only offer an optical stabilization, not in body SR. that's the problem of the Samsung as of the moment, I'm not sure about the Sony.
P.S. I'm considering a portable dslr, the Samsung NX10 might be it or it's successor. let's see how would the pricing go after a couple of months.
