The af330ftz and af500ftz don't have A mode (they have no light sensor of their own). They are either TTL or manual.
K-m (or any other Pentax K-series DSLR) doesn't support TTL flash.
So you can use the aforementioned flashes only in manual mode.
The af500ftz has variable power so is a bit more flexible.
In any case, you'll need to know the guide number of the flash, and adjust aperture and the ISO setting to match the distance from the flash to the object to be photographed - not the end of the world, but clumsy.
