Originally posted by cosmicap I used to take startrails with film. The old Spotmatic didn't bat an eye of course at 8 hour exposures.
Not to say that a star trail need be that long but 1 or 2 hours is a reasonable time.
Different matter with digital. My K200 has great battery capacity but I doubt that the Eneloops would last. I look for advice whether to make up a lead with a suitable plug to take power from a 6volt lantern battery such as Duracell and pop it straight into the Dc input. Assuming polarity is correct what could go wrong? Is it a dumb idea? Are there issues with the circuits being open for such a long time. Could I burn anything out?
Keep the wires from the battery as short as possible. At the low low voltage of 6v, you'll experience significant voltage drop during high-amperage demand, like opening the shutter and flipping the mirror. If you can rig up some sort of caddy so the battery can hang on the tripod no more than a foot from the camera, it should work good.
You mention you have a rechargeable lantern battery? I'm willing to wager it's composed of rechargeable AA cells wrapped up in plastic and metal to look like a bigger battery. You could grab a 4 way D-cell holder and four NiCad or NiMH D-cells (8000-11000mAh) and have an external battery that will likely last for days of continuous usage.
As for damage to the camera from a long exposure, I don't know about the K200 specifically, but the newer K-x and K-7 have protection circuits, which monitor the temp of the sensor and shut it down if it over heats.
