Originally posted by twokatmew Can someone explain the difference between single- and dual action ball heads? Also, are there brands other than Smith Victor for arca-compatible but not-so-expensive ball heads? I like the BH2 from Smith Victor, but all of their heads are out of stock with no known ETA.
Edit: I just found an article on ball heads, so I now understand the dual-action heads also have a panning control. There doesn't seem to be any reference for which heads are arca swiss compatible though.... Here's the link:
LensRentals.com - Choosing a Ballhead.
Your link shows several different types: the first sketch of a ballhead shows an Arca-type clamp, (If it looks like that, it's almost certainly Arca-swiss compatible. If something with a fancier lever or something rather than a screw is, they will usually say so. This'll be like if it's from a maker like Kirk or Acratech or RRS.) and the last photograph in the row shows one as well (I've been kind of eyeing that type, myself.
What the plates will look like, you can see below there, well, somewhat. Basically, it's a dovetail under a flat platform. (Actually, it's the other types that seem more confusing. Those are more likely to be proprietary.
Adorama's 'flashpoint' branded plates, well, I have one. Serviceable, but spending a tad more wouldn't do you any harm.
Usually a head will come with a plate, may as well have a couple.
(One that stays with the tripod bag at all times really isn't a bad policy, that's where my Flashpoint plate usually lives: a somewhat better one sometimes gets left on a camera or something. One does *not* want the experience of lugging a tripod around only to find you have no attachment plate with you. More a worry if you shoot lots of different bodies, ie, with film.
