Originally posted by twokatmew Russell, what tripod are you using in that photo? I'd like to get one that allows me to get shots close to the ground.
Originally posted by hangu More questions:
Which right angle viewfinder is that? Any good?
Which ballhead are you using?
It is a Induro AX-214.
keh.com sells discounted Induro tripods. There are a few, a AX-113 at $85, AX-114 at $95, and a number of the CF CX versions that start at $199. I got to compare the Induro, Giotos, and the Manfrotto XProD tripods all at the same store and came away liking the Induro the most.
The ball head is a Feisol CB-50. It is a pretty large ball head and I think I should have bought a smaller head. Once I learned how to set the tension, I got to liking the ball head. Mine isn't, however, as smooth around the rotation axis as I would like, but it perfectly usable. The sticking is the result of having to keep tension on the rotation. If there isn't enough tension the head rocks in its base.
The right angle finder is a Seagull 1-2x. I like it and it is usually sold for under $50. I use even when I'm not down low so that I can use the tripod collapsed. I usually only extend the top two sections of the legs. I've had it for about three years and it is still like new as far as being tight about its rotation.
To make it easy to use, I used a silver Sharpie to mark the two positions on the barrel where the diopter was correct for my eyes. I just line up the marks in 1x or 2x and start composing or verifying focus.
The Seagull eyecup shares the same universal adapters and
costs around $3, $4 now.. It is a lot easier to use this eye cup with the right angle finder than with the Pentax finder as you simply leave the adapter on the camera. The only issues with the eye cup is that the cup is shaped and I found the rubber to be a bit hard.
To make the eye cup more comfortable I bought another
eyecup for its circular softer rubber cup. The cup fit perfectly as a replacement to the one that came with the Seagull. It can be folded back over the mount and I can use it in this position.
The eye cup does move your eye back from the finder, so there is some shifting of where you look to see the status display. I have gotten so used to this now, that I don't even notice the issue anymore.
You of coarse can just use the Pentax supplied finder, but you should buy the Seagull eye cup anyway just to have the spare adapter in your bag. Nothing is worse than trying to find a dropped black piece of plastic in the dark.
Thank you
Russell
