"In manual mode, the flash will just fire at full power - you can't regulate it." - I don't know where PBO got that idea from. I actually own a AF160FC.
The AF160 has power controls on a dial on the back that lets you choose 1/16 1/4 and 1/1 flash power - the great thing about the AF160 is that these power settings remain consistent Wether you are using the whole flash head or not. Though these power settings only work in full manual mode,if you want to use aperture priority with your ring flash you will have to use either an A, FA or D(F)A series lens
