Having a difficult time deciding on a tripod.
Looking to get a reasonably good tripod to use with k10d heaviest lens is currently my kiron 105mm macro.
Found the "fancier" range of tripods on ebay, which look like a good deal, esp considering everything local in NZ is either overpriced low quality tripods or manfrotto/gitzo etc. So it looks cost effective to get one of these from ebay shipped out to me.
Only difficulty I'm having is that there are over 20 different tripods!
I'm used to tripods with three sets of "flip lock" locking mechanisms on the legs (4 sections).
The two models that look like a match are: FT6694T, and the FT-6828T. Leaning towards the ft-6828t.
The brand is "fancier" made by WEIFENG.
FT-6694T
http://cgi.ebay.com/...efid=store&ssPageName=STORE:HTMLBUILDER:SIMPLEITEM
FT-6828T
most likely this combo deal FT-6828T and FT-6665H Fluid Drag Ball Head
It's the old story of when you want to replace your old $150(nz) tripod which is no longer functioning to requirements, and you gradually creep up the price spectrum getting more and more away from your original scope.
Still I would like to get something that will last longer than a year, and have decent performance.. I don't want anything too expensive because it will get some abuse and I would feel guilty breaking something too expensive.
These carbon tripods I'm hoping will have the lightweight advantage, and be decent quality. Not sure if they have toe spikes, which would be a negative.
Which would you choose?
Thanks
