Originally posted by RobG Doesn't the K1 have a "crop mode" where it crops to APS-C? I guess I'm not surprised by the vignetting since the TC is a DA device not a DFA one?
I don't have a K 1 but from reading about it:
yes, it can be set for crop mode
" The remaining 41 DA crop lenses can be used in the K-1's APS-C crop mode, and at least a handful of them, such as the DA* 55mm, DA 50mm, DA 40mm Limited, and DA* 60-250mm can reliably be used in full-frame mode. We will conduct a detailed investigation of crop lens performance on the K-1 in an upcoming review. "
Read more at:
https://www.pentaxforums.com/reviews/pentax-k-1-review/available-lenses.html#ixzz54sSdPttO
" Any tile in the stills version of the Control Panel can be customized to control the following 38 settings:
File format, JPEG size, JPEG quality
Minimum and maximum auto ISO
AF.S/AF.C, AF points, AF area
Metering mode
AF assist light
Flash mode and flash EV compensation
Program line
SD card options
Crop mode
Focus peaking
Shadow/highlight correction, noise reduction (2)
Clarify enhancement, skin tone, digital filters, HDR
Pixel Shift, Astrotracer, AA Filter Simulator
Shake Reduction, Composition Adjustment, Horizon correction
Lens corrections (4)
SR focal length (manual lenses only)
Viewfinder gird, electronic level
Wi-Fi on/off "
Read more at:
Pentax K-1 Review - User Interface | PentaxForums.com Reviews
Continuous Shooting
Full frame: H: 4.4 fps (70 JPG, 17 RAW) M: 3.0 fps (100 JPG, 20 RAW) L: 0.7 fps (100 JPG, 100 RAW)
APS-C crop: H: 6.5 fps (100 JPG, 50 RAW) M: 3.0 fps (100 JPG, 70 RAW) L: 1.0 fls (100 JPG, 100 RAW)
https://www.pentaxforums.com/forums/pentax-cameras-compared/?c1=Pentax+K-1&c...=Pentax+K-3+II
