Originally posted by Björn Trying to learn using Gimp more since it has enourmous power but have a bit of a steep treshold.
For anybody interested in using gimp more (in windows or mac), check out Partha's latest build
here... It includes a lot of gimp scripts and plugins (my fave being g'mic) and most notably in this 2.8.4 release from Partha, includes a port of v.19 of ufraw... So if you drag a raw file into gimp, it will open in ufraw first for 16-bit adjustments and then export into gimp for 8-bit edits from there.. (Just also note that there is a known bug where if you resize the ufraw window after opening the file, it will crash, so just maximize the window and leave it alone after that).. If you have a beefy system and want/need to do 16-bit editing, I also recommend Partha's 2.9 build of gimp. (Use the portable compile so it's self contained..) 2.9 allows you to edit straight in 16-bit using gimp.. Partha doesn't make linux versions but if you're running linux you know gimp is there for you... ;-)
(Also... if you're into working in LAB, Delaboratory is available on Partha's site, and it's awesome too... 16-bit editor and exports into gimp)
