Originally posted by dlhawes I've read comparisons that said that packing in lots of tinier dots results in more noise in the image, though I don't know why.
Photosite size and noise | Crafting Pixels
TL;DR: Smaller individual photosites get hit by fewer photons per exposure than bigger photosites, so they capture less information and the signal needs to be amplified more to achieve the same level of brightness. But the effect isn't as great as you might think, otherwise a camera with a 33mp APS-C sensor could never compete with a camera with a 24 or 16mp APS-C sensor.
Originally posted by dlhawes The KP does make less noise at 6400 ISO; I figure it's because they pack ten more megapizzles (more or less) into the 90D's sensor
Partly that, but the main difference is the accelerator unit in the KP. The chart I linked to shows that at 500 ISO and below, the KP, 90D and D7500 have similar DR. The greater pixel count and slightly smaller sensor of the 90D means it lags the D7500 across the range, but only slightly. The real difference shows from 636 ISO, where the gains from the accelerator unit of the KP make it leap ahead of both. At 6400, the DR of the KP is 6.32 and the 90D is 5. The difference is even wider at about 5000 - almost 2 stops.
Originally posted by dlhawes Also, when I put a Tamron 150-600 on the same camera, I got less scuzziness in the background.
Nice shot Dan. Still pretty noisy and low-contrast (both could be addressed in PP), but the resolution is good and I agree that the bokeh is much better. That's the second-generation Tamron 150-600? Oh I wish we had that lens in K-mount.
