Originally posted by smf Thanks very much for your thoughtful and detailed response to my post!Best wishes,Stu
Good on you Stu. Here's a few more thoughts on the subject.
I don't think there's a single right answer on how to spend a limited light budget. I've tried various strategies with various lenses. With the DA-L 55-300, I tried to stick to f8 (even at the cost of slow shutter and/or high ISO) because there was a big difference in resolution. With the 55-300 PLM the resolution is good at f6.3 so it doesn't demand the same compromises. With the FA*300 f4.5 (and I'm sure the DA*300 f4 would be the same) it's so sharp that you can shoot wide open if you have to, and that gives a clear 1 stop advantage over the PLM. At times I've pulled out the DFA 100, used f2.8 and cropped, but this is a last resort.
Shutter speed is a hard one. I think with practice you can get a reasonable rate of acceptably steady images of a stationary subject going down to say 1/60th at 300mm (thanks to the SR) where necessary, but the problem is often that the subject isn't still for long enough. I think I adjust the shutter according to how much getting an acceptable shot really matters. If it's a bird/animal that I am likely to see again, I might use a slow shutter to keep the ISO down and/or aperture narrower. If it works, great. If it doesn't work, it isn't critical - there'll be another opportunity. But if it's a bird/animal scene that's unusual or hard to get, I would give more priority to a faster shutter - more chance of a sharp image, and accept that less than ideal ISO is the price to pay, because a non-blurry image matters most, and the chance might never come again.
I'm trying to get better with flash, because it reduces the compromises of aperture, shutter speed and ISO. But it requires restraint - preferably just 1-1.5 stops of fill rather than the flash becoming the main light source.
Originally posted by DW58 New camera and editing software. The three of us are all a work in progress.
All photography is a work in progress in my view! Hey you are doing well. I like the crop/composition: not too tight and it works well.
