Originally posted by Trigger Happy What's the best solution you all have found for *small* lens pouches? The neoprene ones off eBay are way too big for typical Pentax primes, teleconverters etc. I like the sock idea, but would prefer something lint free.
I actually have a set of neoprene lens bags that I bought from amazon in varying sizes. I need to order some smaller ones (a-la the one I have my SMC M 28mm + screwmount lens hood in). I had ordered the standard variety size set (some are way huge) but the small size is about perfect for the 28mm prime, and would also fit well with the 50mm f/1.4 super tak. You can also use a larger bag for multiple lenses, and just put a piece of that multilayer display foam packing that some retail pdq displays use to stop bumping/clanking.
If you really like arts and crafts, you can get some pvc tube with the screw cap ends, some plastic (maybe wonderflex, as it's heat moldable to shape), and some packing foam.... Cut pvc to desired length, put screw cap on end, use wonderflex to create a slide-out insert tray, glue some packfoam discs in-between where you want the primes, load it up and put other end on. Then you have a storage tube. Just make sure all the primes you want to load in there are about the same diameter to fit inside the tube with the tray, and not small enough to jostle around.
