Originally posted by Tamia I gave it a try with my ND 0.9 filter and with a circular polarizer. Though I could see faint birefringent colors through the viewfinder when using the ND, they didn't present in the photos I shot. Tried with the polarizer and the colors were striking. Used a filter case for the test. Here are the results:
ND Filter
Polarizing Filter
Thats a normal ND filter.
Variable polarizers are made with two CPL's mounted together. When you rotate one of the CPLs, it acts like a ND and will get darker and darker until you hit the equivalent of an ND400.
If you have two CPLs and hold them together and turn one, you'll see them effectively dampen any light coming through.
I just checked with the cracked ND I received the other day - you can see the rainbow effect to a small extent through both a pyrex measuring cup (mostly the handle) and a plastic Pepsi bottle.
I then grabbed the CPL (same brand - I suspect the ND is two of those same CPLs mounted against one another) I picked up at the same time and the effect was MUCH stronger.
