Cool thread! I've posted this elsewhere, but this is another suitable venue.
This is a twofer: I'm using a lens in reverse (DA 35mm f2.4), with a de-glasseed Pentax K lens to Nikon F body adapter, with aperture control, to operate the 35mm's diaphragm.
Here's the adapter:
Here's what the reversed Fantastic Plastic can do on the KP:
and at 100%:
Another:
and again at 100%:
So, two wrongs do make a right!
Originally posted by MossyRocks A reverse mounted DFA 100mm f/2.8 WR Macro on a 17-31mm helicoid on my K-3ii. The aperture lever was controlled by hand and was somewhere between f/10 and f/16. Having that lens reverse mount on that helicoid it focuses from a little past infinity into the macro range.
This sounds a lot like a set-up that Lester Lefkowitz mentions in passing in
The Manual of Close-Up Photography (highly recommendd!). On page 106, he shows a rig combining a reversed 70-210 on 63mm of extension tubes, which goes from 3x macro, to infinity! How many macro set-ups cover that sort of range? Not many. I'd had the book for a while before I noticed this example. I didn't even know this was even possible (and workable) until I came across this. I put it together from parts I had, just to satisfy myself that it would work, and it does! It'sheavy and akward, but works as advertised. I didn't do much more than try some quick indoor shots, but nothing really worth showing. I'll have to revisit this combination and try it out some more, just for the hell of it!
