end of month wrap up....
early on, I had a used copy of the DA 18-250mm f3.5-6.3 ED AL (IF) and loved it; when the focus gears wore out, I sent it off for repairs and it was determined that the parts were not available for a repair with out a donor lens, so I had to let it go...
I've missed it... and tried to fill that hole with several other superzooms and none of them ever had the colors or focus of the 18-250 - I've had a good copy of the DA 18-135mm for a while, but that lens just wasn't "it"...
so when I came across a NIB copy of the 18-250, I bought it.... and here we go:
it is a superzoom with a 'slow' aperture that gets worse the further out you go in focal lengths.... so you need a truckload of light to avoid having to run higher ISO....
MFD is reasonable, but allows for close up shots at the further focal lengths...
significant barrel distortion at 18-20mm, but almost any post-processing software will cure that, plus the lens will also give you purple fringing if you aren't careful about bright highlights/backlighting...
typical plastic build quality for a consumer zoom lens - zoom ring is nicely-damped, but the tiny focus ring has that expected plastic grittiness to it...
but - it is a superzoom, not a highly-corrected prime, so this is a lens of convenience not art...
or is it?
gimme some shots from the month... how about some bokeh?
or some color?
but the convenience of 18mm to 250mm is hard to ignore...
18mm:
250mm:
so - hugely capable, convenient, and actually quite competent....
the rest of my month:
Single in Challenge - October '21 | Flickr
