It's time to take stock. It is unlikely that anyone will jump into the last car.
On the advice of Grimus, I will tell you how I did my own processing.
First I Corrected the geometry. Crooked pillars and walls are very distracting. Then I cut off the negative space at the bottom, as well as the pedestrian sign and traffic light on the right. They drew attention to themselves.
Next, I applied an interesting processing method that I found on YouTube.
Exposure -2.5, Slight contrast reduction -5, Highlights -100 Shadows +100 White +70
In the HSL panel, the saturation of all colors is -100, converting the image to black and white. At this stage, it becomes clear where there is not enough illumination. A small S-shaped edit in the curves. Two masks. A gradient darkening the sky and a radial gradient in front of the first car.
Next will be the most fun. We are starting to return the color on the HSL panel.
A cinematic picture usually represents a limited number of colors. I chose the triad scheme. Orange as the main color. Both blue and red are additional colors. I added a little while remaining in negative values and changed the hue.
In conclusion, a little clarity and dehaze.
---------- Post added 12-18-22 at 10:41 PM ----------
Looking through your options, I liked the idea of jheu02 about the black and white option.
It's almost a monochrome scheme in color theory.
And to increase the cinematography, I skadriroval in a different way. Aspect ratio of 1x2.35 widescreen cinema
---------- Post added 12-18-22 at 10:42 PM ----------
Based on all of the above, Kerrowdown coped with the task best of all.
Second place - xs400
