Originally posted by mikeSF JMR,
those are amazing. might you share some insight on how to perform the technique you used for the #1 photo (B&W landscape) above? did you stack a lens blur layer in there?
thanks
Exactly. Duplicate a layer, and apply Gausian blur to one of them. Adjust levels and contrast on both layers, convert to BW. You may choose to leave each layer separate and convert separately and adjust that way, if you prefer. For BW, there is the added bonus that if a given coloured image is not balanced, you can make it so by converting to BW. One note, gausian blur is not a panacea for bad images, and should be judicially applied where you think the image can benefit from a softer look.
If you use a tripod, you can also do double or multiple exposures. The trick is take one at half exposure in focus at desired aperture, and the second half exposure and out of focus using minimum depth of field (shallow, like 2.8-5.6).
Thanks for the comments and your interest.
JMR
