06-24-2009, 03:44 AM   #61
cheekygeek's Avatar
Thanks for the reply, but what I mean is that, with the reverse adapter, the top LCD shows ONLY a F-- (no other information) and in the viewfinder I see only the blinking F-- and shot count (even on M). I can't change the shutter speed, I can't take a shot, I can't take a preview. (K200D)
06-24-2009, 11:20 AM   #62
Damn Brit
Guest
That sounds like a problem with the contacts on your camera. Try cleaning them with a pencil eraser.
07-09-2009, 05:17 PM   #63
Damn Brit
Guest
I decided to play around some more today. This time as well as the reversing ring, I used a set of extension tubes. I used a macro focusing rail and also utilised Live View for the first time which I enjoyed. I was fighting bright sunlight so I used a towel to cover my head and the LCD. It wasn't perfect because there was a breeze as well.
Bear in mind that this is a learning process for me and I will post some shots that didn't work so well.
Second one is a crop, it's a feather in case you don't guess.
The fourth one is a piece of petrified redwood (from Greece).
The last one I was quite pleased with, a strawberry.
07-19-2009, 04:08 AM   #64
MattGunn's Avatar
There are some fantastic photos in this thread, way better than I have achieved. However there are a lot of misconceptions about the purpose of reverse rings and how to use them to best advantage. I will try to explain.
Firstly, macro shots (beyond what the focus travel allows) can be taken with any lens if it can be moved further from the film / sensor somehow (extension tube or bellows normally). This generally works better with primes than zooms as they will generally have less glass in the way and so introduce less aberrations when used outside what they were designed for. When the length of the extension tube or bellows is equal to the focal length of the lens you have achieved 1:1 magnification i.e. the image on the sensor / film is the same size as the object.
Lenses are optimised (designed) to work over a defined range of object distances which will be the range over which the focus ring allows you to work. If you use a normal prime lens with extension tubes to achieve 1:1 magnification, it is being used outside what it was designed for and so it will not perform at its best. In addition to having a significantly longer focus travel, macro lenses are also optimised to work closer to the object (so a 50mm macro will NOT be as good at taking landscape images as the equivalent 50mm normal lens).
For normal photography the distance between the object and the lens is greater than the distance between lens and the sensor. If you want to achieve a magnification greater than 1:1 the distance between the object and the lens will be less than the distance between the lens and the sensor. In this case the lens is being used well outside of what it was designed for and the performance will be reduced. If the lens is used reversed for high magnification macro (long extension tubes of bellows) then it is as if it were being used the right way round for a distant object i.e. it is being used how it was designed for. The higher the magnification the better the lens should work reversed (but the harder it is to illuminate the subject well)!
Now it just so happens that if a short focal length (maybe 50mm or bellow) lens is reversed then it will generally give a closer macro than if it were used the right way round. If a long focal length lens (maybe 80 mm and above) is used reversed without an extension tube or bellows then it will be IMPOSSIBLE to focus at ANY distance (the lens it trying to focus beyond infinity).
So in summary, if you want a low magnification then use the lens the right way round, with an extension tube / bellows if necessary. If you want something around 1:1 macro the a purpose designed macro lens will give the best results but a lens either the right way round or reversed will work with extension tubes. If you want a magnification greater than 1:1 then a reversed lens on extension tubes should work best. I hope that this helps and is not too confusing (it is difficult to explain without using terms like conjugates and numerical aperture).
Bellow is a picture I took with a reversed lens (I can’t remember if it was a Helios M44-2 or a Takumar 55 f/1.8) at about f/11 on a long bellows extension. The image is of some Vanadinite crystals and the area of the image was about 5mm across.
07-24-2009, 03:18 PM   #65
Damn Brit
Guest
Thanks.
I like yours, I tried some crystals but wasn't happy with any of them. Lighting is tough, DOF is tougher than usual.
Nice instructional write up as well.
07-26-2009, 03:12 AM   #66
MattGunn's Avatar
I hadn't played with my reverse ring and bellows etc for a while, but the fantastic photos everyone has been posting have inspired me to dig it all out again and have another go.
The first photo was taken using a reversed Super Takumar 50 f/1.4 and the sencond two with a reversed Super Takumar 55 f/1.8. In all cases the lenses were reverse mounted on a pentax auto bellows and for the second photo a full set of extension tubes was used in addition to the maximum bellows extension to magnify an area only 3mm across. All pictures taken at f/16 to get the depth of field and all lit by a tungsten spot lamp.
08-02-2009, 09:51 AM   #67
pete_pf's Avatar
i ordered myself a reverse macro adapter just over the weekend, can't wait also an extension tube, we'll see which is more fun
yay for cheapo photographers who can't afford macro lenses ... yay hehe
08-02-2009, 10:12 PM   #68
Damn Brit
Guest
QuoteOriginally posted by zenimagery Quote
I look forward to you posting some images in this thread.
Don't call it cheapo, call it alternative (and fun).
08-03-2009, 09:06 PM   #69
sfdealer's Avatar
Thanks for the inspiration. Reversed Pentax-A 50mm 1.7. Rose Garden in Golden Gate Park.
08-04-2009, 12:16 AM   #70
Damn Brit
Guest
Hand held, pretty good.
08-04-2009, 10:40 AM   #71
pete_pf's Avatar
QuoteOriginally posted by Damn Brit Quote
do you mean you attached the lens with reverse ring to the extension tube? does it focus even closer?
oh please, you know you're a cheap ass alternative indeed. granted a macro lens would be killer, but having to manually focus and expose you are really forced to think a little more technically about your shooting, which is fantastic
08-04-2009, 03:53 PM   #72
Damn Brit
Guest
I didn't really check, I'm not sure if it focused closer or magnified more, or both.
If I was a cheap ass, I wouldn't own two macro lenses as well. I agree about the thinking more technically, I think that's the main thing that I enjoy about it.
I will acquire bellows at some point. Also, although annoying, I like the fact that I spend time setting up a shot only to find that once taken, the subject wasn't really suitable. I guess I have a masochistic streak as well.
08-07-2009, 06:24 PM   #73
pete_pf's Avatar
ok, i couldn't wait for the adapter ring, so i started taking a few shots just holding my lens backwards.
defiantly not tack sharp, but i kinda like it. quite artsy don't ya think? .... whenever a photo doesn't come out good, just say it's art, and you'll have people that love it haha
this one, i was also playing around with the triggers i just received (not sure how i lived without off camera flash all this time) and my diy grid spot looks kinda cool i think.
a have a few more i'll upload later.
08-08-2009, 10:58 PM   #74
Damn Brit
Guest
If you were famous you could call it art.
08-08-2009, 11:22 PM   #75
pete_pf's Avatar
i am famous, in my own head. don't ruin that for me.
one more
adapter, fun, macro, thread
More on new Samsung NX and continuing relationship with Pentax nixcamic Pentax News and Rumors 49 05-02-2009 10:16 AM
Continuing Shots from This Week. Jimbo Post Your Photos! 11 04-11-2009 07:08 PM
How Dumb is your Governor? (Fun Thread) Damn Brit General Talk 21 02-13-2009 04:59 PM
The Continuing Adventures of Technology that Breaks.. Artymous Photographic Technique 0 12-17-2006 12:08 PM
All times are GMT -7. The time now is 03:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
