06-17-2018, 05:00 PM   #991
Here is what not to do
Just joined the forum as i blew this great opportunity (Blur)and looking for feedback on my settings .Pentax K50 with Pentax -DA 1:4.5-6.3 55-300mm ED PLM WR RE
All the photos where shot at ISO 100 55M -0.7ev F/5.6 1/125
PENTAX K-50  Photo
PENTAX K-50  Photo
PENTAX K-50  Photo
PENTAX K-50  Photo
PENTAX K-50  Photo
PENTAX K-50  Photo
06-17-2018, 05:46 PM   #992
PancakeFlipper's Avatar
QuoteOriginally posted by Ramcam Quote
Start out with a faster shutter speed. Are you using a tripod? I like using a tripod with a gimbal head. It gives support and Iím able to move the camera around to track the birds easier. But I think at minimum a faster shutter speed to free action and minimize blur.
Hopefully youíll have another opportunity to photograph this. Itís amazing to see
06-18-2018, 04:12 AM - 2 Likes   #993
RockvilleBob's Avatar
Red Finch auditions for Batman Movie
NIKON D500  Photo
06-23-2018, 08:31 PM   #994
Des
Des's Avatar
Here is what not to doJust joined the forum as i blew this great opportunity (Blur)and looking for feedback on my settings .Pentax K50 with Pentax -DA 1:4.5-6.3 55-300mm ED PLM WR REAll the photos where shot at ISO 100 55M -0.7ev F/5.6 1/125
QuoteOriginally posted by PancakeFlipper Quote
Start out with a faster shutter speed. Are you using a tripod? I like using a tripod with a gimbal head. It gives support and I’m able to move the camera around to track the birds easier. But I think at minimum a faster shutter speed to free action and minimize blur.Hopefully you’ll have another opportunity to photograph this. It’s amazing to see
I agree about the shutter speed. With birds in flight you really need to prioritise a fast shutter speed even at the expense of aperture and ISO. With the K-50 you can take the ISO to 3200 if necessary if the light is reasonable (although if the light is good enough to get by with less, so much the better), and the PLM lens does quite well at its maximum aperture, so there is some scope. Shooting at the wide end of the range (55mm) is more forgiving than shooting at the long end - you already have greater depth of field and can often get away with a slower shutter speed than you can at the long end (because slight camera movements will have less of an effect than at longer focal lengths). But to account for a fast-moving subject you really need to use a much faster shutter - something like 1/500th second at the minimum. I have one of my User settings devoted to birds in flight - I use shutter priority (Tv), a default shutter speed of 1/1000th second and an ISO band of 100-3200. That is about the only situation in which I use AF-C and multi-point autofocus. In this User setting I also have the camera set for shutter-button and back-button AF (I usually use back-button only), single-point metering, RAW only, and continuous shooting at the highest rate.
The best settings for BIF have been discussed a few times here. See this thread for example: Focus help with K-3 birds in flight - PentaxForums.com I think you just need to try a few different settings and see what works best for you.
Interesting effect using the wide end of the telephoto lens. Gives more context. One thing is that if the bird occupies only a small part of the frame (because the lens is zoomed out to 55mm), the AF will have a harder time getting a fix on it, because the subject won't cover a lot of the AF points. If you zoom in a bit, so the bird is bigger in the frame, you might find it easier to keep in focus.
I can't gainsay the point made by @PancakeFlipper that a tripod and gimbal are advantageous. But I'd have to say that my experience is that BIF opportunities often don't allow for anything but handheld shooting. Just try to make sure you get a good grip and stance. I like to stand side on to the subject, with the left elbow in tight, the left hand supporting the lens and pivot with the hips - but that's just me.
Incidentally I think you did pretty well in tracking the eagle and keeping it roughly in the centre of the frame, @Ramcam. That's not easy. You are well on the way.
06-24-2018, 01:42 PM   #995
Sparrow Checking you out
Focus is still a matter of some luck but sometimes you get an interesting shot.
NIKON D500  Photo
06-26-2018, 05:18 AM - 1 Like   #996
Grey Turaco
06-28-2018, 10:50 AM   #997
Another attempt - small birds in flight
NIKON D500  Photo
06-28-2018, 01:54 PM   #998
06-28-2018, 08:14 PM - 1 Like   #999
Better results with suggested settings thanks everyone.
PENTAX K-50  Photo
PENTAX K-50  Photo
06-28-2018, 09:13 PM   #1000
Des
Des's Avatar
Nice work. If you can get swallows in flight, everything else is easy. :-)
06-29-2018, 01:34 AM   #1001
06-29-2018, 12:57 PM   #1002
Was lucky to get a few at Zoo Lake today, a (common) skirmish between rivals of Egyptian Geese.
07-04-2018, 03:59 AM   #1003
Arjay Bee's Avatar
A bird that may not have been posted in this thread before - a Gannet on the prowl, it was dive fishing for bait fish near the Matapouri river mouth in Northland New Zealand along with a couple of mates. Wonderful to watch as they penetrate the water from a height of about 8-10 metres above. Didn't catch the dive but the soaring on the I metre wing span is beautiful. (K3 & DA 55-300 HD)
07-04-2018, 06:43 PM   #1004
QuoteOriginally posted by Arjay Bee Quote
Wonderful capture, sir. Truly breathtaking. Thanks for uploading.
tt
07-10-2018, 06:08 PM - 5 Likes   #1005
RDP
Shot in Maryland over the Potomac. K-3, HD 55-300 (at 300). 1/500, f8, iso 320
PENTAX K-3  Photo
albatross, australia, birds in flight, egrets, flickr, gear, grant, gulls, heron in flight, island, jpg, jul, k100d, macro, pentax, people, photography, pm, post, pp, rod, shot, shots, shutter, silver, swallows, tamron, terns, victoria, vultures
Nature BIF with 16-45 gdog Post Your Photos! 0 01-26-2010 03:39 PM
BIF My First Damn Brit Post Your Photos! 10 07-12-2009 07:47 AM
K 7 bif snooked Pentax DSLR Discussion 0 07-11-2009 07:36 AM
Motif No.1 and BIF Keltech Post Your Photos! 17 02-28-2009 11:06 AM
DA* 300mm F4 BIF snooked Pentax SLR Lens Discussion 8 07-25-2008 06:39 AM
All times are GMT -7. The time now is 06:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
