04-11-2011, 04:23 AM   #1
hello from Melbourne...
im jon from melbourne....hope to learn a lot from you guys...thank you...
i just a bought a used K-7 on ebay...and the camera is in near mint conditon...but what i noticed about the camera or maybe the lens i mounted..which in particular is the sigma 70-300mm apo dg macro...is that there's a grinding sound coming from the lense when zooming in and out...but if i mount the lens on my K100D super there's no such noise...i tried my other lenses and they dont make any grinding sound as the 70-300mm does on the k 7...
hope someone here can help me out...
thank you....
04-11-2011, 04:51 AM   #2
RobA_Oz's Avatar
Hi jon, and welcome to the Forum.
Do all the lenses you have make that noise on the K-7, or is it just the Sigma? Either way, it sounds like there's a misalignment of the drive shaft in the camera body and the mating shaft in the lens, which could be eccentricity or axial compression (ie they're not turning along the same axis of rotation, or one is pushing too hard against the other, respectively). If you're not confident about tackling the mechanics yourself (and most people wouldn't be), I'd suggest you contact the Australian service agent, C.R.Kennedy, about it. Good luck with it.
Rob
04-11-2011, 05:01 AM   #3
Hi jon!
04-11-2011, 12:18 PM   #4
thanks RobA...
just the sigma 70-300mm...but just like what ive said above...if i mount the 70-300mm on my K100D super it doesnt make any noise at all...ive tried all my other lenses on the K7 and they all work properly without making any noise....
hello tryphon4...
04-11-2011, 02:41 PM   #5
RobA_Oz's Avatar
I'd suggest something on the Sigma is out of tolerance, from what you say. All mass-produced goods have to have an amount of tolerance on dimensions (otherwise, they'd be too expensive for most people to buy). I'd be checking the lens. Fortunately, Kennedy is the agent for both Pentax and Sigma, so an enquiry there would be a good start.
70-300mm, camera, lens, sound
Hello from Melbourne. pickles Welcomes and Introductions 6 05-21-2010 05:20 PM
Hello from Melbourne simonb Welcomes and Introductions 3 05-08-2010 06:03 PM
Streets Melbourne xhanatos Post Your Photos! 23 03-23-2010 10:55 AM
Architecture Melbourne fractal Post Your Photos! 5 02-22-2010 04:29 PM
Hello from Melbourne, AU. schitzengiggles Welcomes and Introductions 2 02-14-2010 02:05 AM
All times are GMT -7. The time now is 01:59 PM. | See also: NikonForums.com, part of our network of photo forums!
