Originally posted by crunch01 I will have under 7,000 invested in new system..
To compete with staying with Nikon I would be investing at least 8,000 or better any way.... i would need 2 new Nikkor lenses for the new metering tech from my older film camera's.. the older lenses will work on the newer camera's but wouls have the same older metering type.. to gain full advantage of newer meter's needs newer lenses....
Doesn't the D7000 have a special module to work with older lenses?
I'm really not sure what it was called but I was told it was new and unique to that effect(might be worth checking out).
Quote: Also I do not like the supper large bodys.. uncomfortable for me to shoot fast pinups hand held in studio.... sooo for me it seem's i can beat Nikon or cannon quality for this size camera for same of less investment.... If i lose mony on lenses i have used for 15-20 years and they cost me 5,000.00 then i still got my money out of that investment a long time ago.
Off the top, I believe the D7000 is approximately the same size and weight as the K-5.
Quote: I hit all the forums and review site's compared noise at all ISO's and color rendition and i feel K-5 blows away the Cannon and Nikon camera's in the top price range....
I'll sum it up the K-5 IS Pentaxes HIGH end SLR equivalent.. It has the Image quality to back that statement up.... If any one askes me about my Pentax when i am out of studio or on my image data... 1 they are propobly NOT a pro.... 2 I'll show them the Photos.. lol if it will show a small peach fuzz blond hair on a full body shot when blown up it win's and when i tested it in the store it did.. besides if the shot is a glamor shot it is soft focused so as not to show that detail.
Sounds good. And I think much of this comes down to whether you shoot RAW or JPG. Though just so you know, the D7000 has the exact same sensor as the K-5. Except for one slight difference, it has a slightly weaker AA filter which I believe falls in the give-and-take category. And that's where it produces slightly more microcontrast out of camera at the expense of added moire. Which isn't quite in line with some of the worst camera's out there, but I thought it was worth mentioning just the same.
However on the flip side, the D7000 does hold an advantage over the K-5 in the high ISO department. And that is where it does not add low level NR at higher ISO(ISO2200-51200). Which may or many not affect you depending on what high ISO bracket you shoot at, However, it does present a notable difference between both systems, which ironically translates to the D7K seems producing better ISO6400 images than the K-5. Which I myself find rather odd given that Pentax would have benefited from holding off NR until AFTER ISO6400, but... it is what it is. Either way, the K-5 picks-up past this point by producing consistently better high ISO output beyond this point. Anyways, I'm not trying to confuse you with this and so I'll just leave it at: Advantage D7K up-to ISO6400 and then K-5 beyond that.
Having said all that, at the risk of sounding as though I'm trying to discourage you from investing in a Pentax body. I want to reassure you that, that's not what I'm trying to do here. However... as a firm believer in product research when it comes to camera investments, I figure its better to lay all the cards on the table in cases such as these. Otherwise, you might find yourself frustrated for not thinking things through prior to investing.
ps. There are many people here(including myself) who shoot both Pentax and Nikon. And though I'm not a fan of the D7K myself(for other reasons), I still think it holds certain advantages over the K-5.
Oh,. and be sure to consider the flash systems between both kits if you're into or planning to do flash photography(very important).
Hope this helps.
