10-05-2011, 02:37 AM   #1
Hello from a novice
Hi my name is Kaz and I am very much a novice in the photography stakes. I am hoping for some some advice from all you professionals. I have just purchased a Pentax k-r and the guy at the camera shop said it was a good choice as Pentax was the only make whereby you could use any lens from other Pentax models. This was a bonus and the major selling factor as far as we were concerned as my hubby had quite a fab range of lenses from his now defunct non digital Pentax.
We bought all his lenses on holiday with us only to find that they do not fit the k-r, is this because they are from a non DSLR and if so is there any sort of adapter to solve the problem, would be such a great shame for his lenses to go to waste?
Any advice would be most welcome.
Thanks in advance.
Kaz522
10-05-2011, 02:47 AM   #2
MRRiley's Avatar
First, Welcome to the forum. We're not all pros, but the sheer amount of Pentax AND photography knowledge represented here is humongous.
Second, The lenses should fit one way or the other. Compare their mount bases with the lens you bought with the K-r. If they are bayonet mount lenses made by Pentax (have to be careful with some other brands as there can be slight differences) they should fit right on. If they are screw mount, then yes you will need an adapter. Look or ask for a "K mount to M42" adapter. Basically, you put the adapter on the camera and then screw the lens into it. Metering and automatic functions will not work of course, but look through you manual on how to use these older lenses.
Good luck and I hope this gets you shooting.
Mike
10-05-2011, 02:57 AM   #3
Thank you so much for your speedy response and welcome Mike, that is the problem the k-r is bayonet and the other lenses are screw. We shall now try and find somewhere in Malta where we can purchase the adapter. Big relief that we can use the lenses eventually though
Cheers.
Kaz
10-05-2011, 03:03 AM   #4
sam-joseph's Avatar
Welcome Kaz. There is an affliction that affects all camera users at some point, called LBA. I'm sure you're on the verge of this particular affliction. Don't worry though, the cure can be found on ebay, or the Pentax Forums marketplace. You just purchase a well-researched lens, and you will feel better for a while.
Regards
10-05-2011, 05:34 AM   #5
MRRiley's Avatar
See if you can find an older established camera store. They will be more likely to have a couple of adapters squirreled away somewhere.
Mike
advice, k-r, lenses, novice, pentax
Novice help kevins Pentax DSLR Discussion 17 01-01-2011 09:51 PM
Novice Help Blerg Pentax K-r 8 12-13-2010 09:07 PM
K1000 - Novice Needs Help Please dkinkaid Troubleshooting and Beginner Help 34 11-28-2010 09:19 PM
Novice need help. roscopecotrain Troubleshooting and Beginner Help 11 10-18-2010 07:55 AM
A new K-x for a novice wench.weber Welcomes and Introductions 3 02-28-2010 08:18 PM
All times are GMT -7. The time now is 04:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
