09-05-2012, 05:57 AM   #1
dpowerherndz
Guest
Hello from Spain
Hello fellow pentax users!
I recently bought a k-5 and am happy with it but unfortunately had to send it back for servicing. I will explain that in better in a another thread in the right forum. Basically, upon switching on the camera, sometimes the sensor locks itself in a crooked position and so all the pictures are significantly crooked. This happen randomly, about 30% of the time. I have seen this forum someone with a K-7 that had the same problem (even posted a picture of the angleed sensor). So I joined the forum to get reviews on lenses and also see if other pentax users, especially k-5 users, had had the same problem. Attached are two photos showing the problem using a 8mm lens and using a 55mm lens. Unfortunately I was unble to photgraph the corroked sensor when it happen but here is a like to somehow had the same problem:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/66210-k-7-crooked-sensor.html
Has anyone had this problem? How was it fixed?
Cheers!
PENTAX K-5  Photo
PENTAX K-5  Photo
09-05-2012, 03:25 PM   #2
eaglem's Avatar
Welcome to the forum, if you ask your question in the Pentax K-5 forum I'm sure you'll get your answer.
09-10-2012, 09:52 PM   #3
Transit's Avatar
Welcome !
A lot of my shots lean to the left but it is a brain issue I think
forum, happen, k-5, lens, pentax, sensor, users
Hello from Spain Dial Welcomes and Introductions 4 05-20-2011 05:15 PM
Hi from Spain Dagger Welcomes and Introductions 2 02-25-2011 04:40 PM
Hello from Spain Justin Allard Welcomes and Introductions 3 11-29-2010 02:38 AM
Hi from Spain. oinotna Welcomes and Introductions 4 10-29-2010 05:35 PM
Hello from Spain johnmb Welcomes and Introductions 2 09-18-2010 01:48 PM
All times are GMT -7. The time now is 06:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
