10-30-2012, 12:23 PM   #1
Hi There - New
Hello All;
I thinking I Should have joined this group in Feb last year when a I purchased the K-r.
I know I have an issue with the Auto/Manuel Flash failing to discharge a flash.
I have reset it to the default factory settings: with no resolution. Still no flash.
The battery is well changed and the camera flash has not been used a lot, so I doubt it is burned out.
Other then returning it to the repair center, what options do I have left?
Any input would be grealy approicated so much. thank you.
Theresa
10-30-2012, 01:57 PM   #2
Welcome to the forum.
Are you saying the flash on the camera is not working or a external flash?
10-30-2012, 03:08 PM   #3
the internal flash will not flash.
I have tired to use the external option with wifi flash and it will not flash either.
10-30-2012, 04:08 PM   #4
Sounds like something is wrong with the flash on your camera. Does the external flash fire if you mount it to the camera. Has the flash on the camera ever worked? Also not to be insulting, but I assume you have popped the flash up. :-)
flash
All times are GMT -7. The time now is 01:09 AM. | See also: NikonForums.com, part of our network of photo forums!
