11-08-2012, 08:08 PM   #1
Hi
Hi, everyone. I visit here every now and then and lurk, so I thought it was time to join up.
I've had a K10D for about 10 years. I've used it almost exclusively for outdoor photography, but with a baby on the way I am looking to get some prime lenses for shooting indoor. All I have right now is a Tamron 18-250. We have a Canon G11 that was pretty decent for in-home pics, but it recently decided not to work anymore
I look forward to reading everyone's thoughts about different lenses, and hopefully buying some lenses through the B/S/T forum.
11-08-2012, 09:43 PM   #2
hi
11-09-2012, 06:30 PM   #3
patrick9's Avatar
Welcome to the Forums
11-09-2012, 07:46 PM   #4
rbefly's Avatar
Welcome!
Hello BlackTalon, Welcome to the Forum!
I own a K10D also, and found that with manual-focus lenses, it became necessary to buy a split-prism focusing screen. The regular screen just wasn't cutting it, and this seems to be true for most digital cameras.
If you stick to A/F lenses, it's not as much of a problem, but still does pop up occasionally. Particularly with macro and under difficult (dim) lighting conditions, the A/F function needs help.
That issue aside, I'd suggest a 50mm f1.7 or 1.8 for your first lens. Nice angle of view, good for portraits and low-light situations, like indoors. A fully-manual "M" will cost about $50-$75, an "A" (auto-aperture, manual focus) between $75-$100. Auto focus "F". "FA", "DA" will run $200-$250.
From the fifty, you could build in each direction, generally halving or doubling the focal length. A 24mm or 28mm, then a 100mm to 135mm. All f2.8 or faster.
Over time you might want to squeeze in a 15mm, 35mm and a 70mm, 77mm or 85mm, depending upon your budget, of course. A 200mm is handy for longer-range shots.
Of course, you could fill in spots with a shorter range zoom, but f2.8 zooms are pretty expensive and I've always preferred primes for low light conditions and ultimate sharpness.
Good Luck!
Ron
11-09-2012, 08:41 PM - 1 Like   #5
Ron, thank you so much for the lens advice -- it sounds like a good approach. I will look for a 50mm first.
I hear you about the manual focus. That's the one think I have always had issues with on this camera. I was used to the great manual focus screens on the old Pentax 35mm cameras; they were much, much better. I use manual focus a bot when shooting around the garden, etc., and often get disappointing results becuase I was off a tiny bit. This would be a worthwhile investment for me.
« hi all | Greetings »
lenses
Hi!! CourtneyRae51 Welcomes and Introductions 3 02-10-2012 12:33 AM
Hi! felmarpesado Welcomes and Introductions 3 02-06-2012 06:46 PM
Hi... sonipratomo Welcomes and Introductions 2 09-20-2011 03:26 AM
Hi sydsam Welcomes and Introductions 2 06-21-2011 12:26 PM
Hi from HI (hawaii) rapphaelray Welcomes and Introductions 8 01-25-2007 10:21 PM
All times are GMT -7. The time now is 06:26 AM. | See also: NikonForums.com, part of our network of photo forums!
