Originally posted by rbefly Hello Jag, Welcome to the Forum!
Adam's right, the FA 28-80mm lens is not very good.
You would be much better off with the kit wide angle zoom, the DA 18-55 f/3.5-5.6 AL. You can pick these up easily (used) for under $100. There is also a WR (weather resistant) version that costs more, but is well worth it.
The one you DON'T want is the DA-L. That's the cheaper version that (usually) comes bundled with a body. It has a plastic (as opposed to metal) bayonet, no hood and has little resale value.
The 18-55mm will cover wide angle to mid-range, dovetailing nicely with your telephoto zoom.
Check the lens reviews for more info and examples of photos taken with this lens. It's considered one of the best kit zooms around.
Good Luck!
Ron
Thanks Adam and Ron, shall i keep my Pentax 21870 DA 50-200mm F/4-5.6 AL WR and get the smc DA 18-55mm F3.5-5.6 AL WR Lens?
