Hi,
I'm brand new to this forum, and relatively new to quality photographic equipment as well. I thought I'd post to introduce myself an recount a recent incident involving my K5 ,15mm Ltd, and a 1 metre deep pool in a river. My work involves working around, and in, rivers on a regular basis. It also involves taking many photographs to capure details of river morphologies and sediment distributions. Late last week I was crossing a small river to take a required upstream view of a particular location when the unstable bed on a run into a pool gave way beneath me
. I was carrying the K5 with 15mm LTD on a sling, and had the camera on and lens cap off. As I fell the camera swung below me and descended to the bottom of the pool to a depth of approximately 1 metre. It was in sub zero temperatures and the water entered my waders
. In such circumstances my reactions are lightning fast and I exited the water before I knew it. Only once on the bank did I realise that the camera and lens had taken a bath
. I was cursing the lack of weather sealing on the 15mm Ltd but rapidly dried the exterior of the camera with a trek towel whilst descending into despondend mire
anticipating the ruination of my recently aquired equipment.
To my amazement there appeared to be no water within the 15mm Ltd lens . Once the outside was dry I removed the lens expecting water ingress into the body; but no sign of water having entred the body through the lens mount was evident
. I wiped the contacts down with the trek towel and remounted the lens. Work dictated that I carried on, and I took a further 60 photogrpahs that day. All turned out fine and no subsequent fogging of the lens or internals of the body have occured, despite regular changes in temperature whilst exiting a warm car to photograph a new site in sub zero temperatures
The above is not a recommended way to treat a lovely K5, and even less so a even lovelier 15mm Ltd. But it all does seem to bear testament to the efficacy of the weather sealing of the K5 and the extremely tight construction tolerances of the 15mm Ltd. It may be that there are negative consequences yet to come, but just working for 5 days immediately after submersion is a remarkeable achievement in my book.
