Originally posted by dominique Good to hear you're happy with the new camera!
Well, if it's that bad, I hope you'll be successfull opening and reassembling it.
If you got some macro capable point and shoot or a macro lens, you could take a quick photo of how each step looks like, to know afterwards how the parts went together...
And - a M 50/2 isn't expensive anyway on Ebay. Once you get a new one, I'd recommend a A 50/1.7, so you wouldn't have to always press the green button when not shooting wide open...
Have lots of fun,
Dominique
Good point Dominique,
I do have a diopter set I didn't mention earlier that I forgot about and was playing around with again earlier tonight. It's a +1, +2, +4 set and with those stacked I can get closer than an old guy with bifocals. If I do get frisky and pull that lens apart, I will definitely document it. Thanks for the idea. If I make the video, I'll give you Producer credit. Or something equivalent or better. I did since clean the outside with rubbing alcohol and several q-tips. That helped a bunch but there is still quite a bit of flaking inside and there is one aperature blade, just one, that looks corroded through the lens. But that
one looks really corroded. Everything seems to work fine, as I found out while I was chasing the cat around the house to test it. I am still leaning towards taking it apart, 'cause like you said, I could probably replace it cheap enough if I screw it up. Hopefully it's not any more complicated than a 3-speed bicycle hub. We'll see.
Also, thanks for the 'welcome' Ash. I love this forum so far, and the camera even more. (Even the shutter sounds nice. I like hearing it.)
I'm thinking Sunday for the lens-dissection. Usually nothing's happening so I can stay focused like a surgeon. I'll keep you all posted and a video link if I have enough SD card for the endeavour.
Thanks,
Joe
