Originally posted by Amelia I am a Mother of 4 and Grandmother of 3 girls. Maybe this isn't the right forum for me I was searching for information on scanning.
I am trying to scan negatives mostly 35mm so that I can eventually put them on cd to give to children and grandchildren. There is so many opinions on what DPI to scan them at. I have an Epson V500 and have photoshop 4 and 7 for photo corrections. So far my biggest opstical
is the scanning DPI and dust. The negatives are in very good shape and I don't want to print large photos 5X7 or 4X6 is good enough. Any suggestions. Thanks Amelia
The V500 appears to be a good choice for your needs. Over the last 6 or 7 years I've done a lot of scanning with a V700, which uses the same software.
A key piece of information is that Epson Scan software offers several modes, the most useful of which is "professional" mode. If you go into that mode, you will find a number of options for adjusting images including an automatic adjustment button that works reasonably well reasonably often. You will also find the option for using DIgital ICE, which is a quite effective system for dust and scratch removal. (It won't get all dust/scratches, but it does make things much easier.)
You should review the Epson Scan manual for more information on these functions. You can also consult books about scanning.
Note that if you select the "thumbnail" tab in the preview window, the software will automatically create frames for every image on a film strip, which can be adjusted individually, then scanned as a batch.
In terms of resolution, I suggest that you look for tutorials on the web. Here is a link to one example, which I found very quickly by searching the term "scanning resolution explained":
Scanning Basics 101 - All about digital images
I suggest 2400dpi as a starting point for scanning resolution. This gives you adequately large files for 8x10 prints as long as you don't crop too much. (Note that the abbreviation ppi, pixels per inch, is often used instead of dpi. As a beginner, you might as well use the two terms interchangeably.)
I will give an example of a calculation for resolution: A convenient image resolution for printer output is 300 dpi. If you want to make an 8x10 print, you therefore need an image file that is at least 2400 pixels high (8 inches x 300 pixels per inch.) A 35mm negative is about an inch high. If you scan at 2400 pixels per inch, that gives you close to the needed 2400 pixels of image height. You just have to rescale the image in Photoshop to 8 inches high at 300 pixels per inch.
Seems simple to me, but I've been doing it for 20 years. I suggest that you look at books or tutorials, of which there are many, until you find an explanation that makes sense to you- or see if you can find someone at a local photo club to show you the ropes.
One post recommended that you purchase Vuescan software. Vuescan is quite good. I've used it for many years on a variety of scanners. However, the Vuescan interface is not particularly user friendly.
The capabilities of Epson Scan in professional mode are more than adequate for most users.
Genuinely high quality scanning requires a certain amount of knowledge and practice, but can be quite rewarding. Good luck!
John
