07-15-2013, 03:05 AM   #1
extension tube
hi im just new in the forum and im hoping that you could help me guys with my problem i just bought an extension tube for my pentax k-r unfortunately when i try to take picture its to dark and blurry. i hope you can give me some tips to fix the problem.
thanks
07-15-2013, 03:30 AM   #2
carrrlangas's Avatar
Welcome! You probably need a lens with an aperture ring to use it with that extension tubes
07-15-2013, 03:42 AM   #3
QuoteOriginally posted by carrrlangas Quote
hi thanks carrrlangas im only new in photography. im using 18-55 lens and 50mm lens
07-15-2013, 03:48 AM   #4
Most probably, the extension tubes donīt have a way to keep the aperture lever pulled (black lever on the back of the lens) and the DA series donīt have a way to open it manually (the Aperture ring). Does the 50mm has it? Which version is it?
07-15-2013, 04:12 AM   #5
this is the lens that i use and the extension tube that i bought.
PENTAX K-r  Photo
PENTAX K-r  Photo
PENTAX K-r  Photo
07-15-2013, 04:23 AM - 1 Like   #6
Ok. Take the 50mm lens. It has a ring that has the marks "1.7 2 2.8 4 5.6 .... 22" ok? Notice that the DA18-55 lens lacks this ring, thatīs why it looks dark with the extension tubes
To use the 50mm mount it on the extension tube number 3 for example. Turn the aperture ring (the one with the marks I mentioned before) so that the number 2 or 2.8 is in line with the red diamond mark.
Set the camera on M mode and set the shutter speed to 1/60 (or similar) and the ISO to 400. The focusing is tricky becouse the Depth of Field (Depth of field) is very small at f/2 (remember we set the mark "2" before?)
A way to focus at such short distances is to set the focus at the minimum distance and then moving the camera forward or backwards to achieve focus.
Take a shot and see how it comes out, then adjust the shutter speed higher if itīs too bright or lower if itīs too dark.
07-15-2013, 04:49 AM - 1 Like   #7
Not a Number's Avatar
See this thread on how to meter manual lenses such as your 50mm.
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...k-x-k-7-a.html
07-16-2013, 11:46 AM - 1 Like   #8
Moderator PEG Judges
Kerrowdown's Avatar
Welcome, I'm not a macro person but it seems your getting lots help just now.
07-16-2013, 12:41 PM - 1 Like   #9
Jean Poitiers's Avatar
Welcome to PF and bonjour from France ... some good help here and hope to see an image or two soon ... J
extension, im, tube
Extension tube question? littledrawe Pentax SLR Lens Discussion 20 03-31-2012 06:10 PM
Nature Extension tube test beaker82 Post Your Photos! 2 03-28-2012 07:47 PM
K5 extension tube HennieCoetzee Pentax K-5 2 02-19-2012 04:21 AM
All times are GMT -7. The time now is 09:04 PM. | See also: NikonForums.com, part of our network of photo forums!
