07-26-2013, 09:54 PM   #1
Hello from Ontario, Canada
Hello.
After using a Canon S3 IS for years. ( I wore one out and bought another), I've contemplated an entry level DSLR for quite some time.
After reading about every camera time and time again, I finally decided on a K30.
I'm still not certain I made the right decision. I used the S3 in manual mode consistently and became quite familiar with it and how to use it.
It also had an incredible optical zoom and a teleconverter that allowed for excellent shots at a distance. Lunars, for instance.
I'm very limited with the 18-55 kit lens and miss the ability I had with the S3.
However, in time, and with a lot more money for lenses, I'm sure that I'll conquer the DSLR learning curve eventually.
As a long time member of a Canon community, I look forward to the help and advice here, as a new Pentax owner.
Thanks in advance.
07-26-2013, 10:31 PM   #2
Tako Kichi's Avatar
Welcome to the forum Hydnum from a fellow Ontarian. I too bought a K-30 recently but have been a Pentax user since 1979 (film SLRs). Make sure you check out the dedicated K-30 sub-forum and post up some shots when you get a chance. One of the nice things about Pentax cameras is the fact that you can still use legacy glass (even the old M42 screw mount lenses via an adapter) so lots of additional lenses can be found for not much money if you shop around.
07-27-2013, 04:24 AM   #3
Jean Poitiers's Avatar
Welcome to PF and bonjour from France ... enjoy the K-30 and hope to see an image or two soon ... J
07-27-2013, 11:26 AM   #4
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by Hydnum Quote
Welcome, as long time photographer you will figure it all out fairly quickly, the theory is the same, just the tools are slightly different.
canon, dslr, s3, time
Hello from Thunder Bay, Ontario Canada Pzykael Welcomes and Introductions 4 05-08-2013 01:38 AM
Hello from Ontario Canada AlfredD Welcomes and Introductions 3 10-31-2011 12:29 AM
Hello From Ontario Canada mrclark321 Welcomes and Introductions 3 10-01-2011 05:03 PM
Hello from Ontario, Canada Classvino Welcomes and Introductions 5 04-25-2007 07:38 PM
Hello from Ontario, Canada mrbach Welcomes and Introductions 7 04-13-2007 11:13 PM
All times are GMT -7. The time now is 06:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
