Ooo, sorry to slightly jump all over this (hello by the way, first post
) but do you happen to know how much that lens in the image above is worth, second hand? The reason I've signed up here is because I've been searching for 2 weeks on and off, trying to find out what the lens is worth. A chap in work sadly died not long ago, leaving all his gear to his niece. She isn't into photography and I haven't used Pentax since my dad used to use them a LONG time ago, so I'm trying to value it for her, but I haven't been able to locate a single lens like the one above. Everything I've seen so far seems to be a new model that doesn't have that aperture ring at the base, and even a Sigma rep wasn't sure what the lens was from the serial number I gave them.
Incidentally, I think the previous post has answered the question as I had the same problem. I had to test this lens on a K-x so was completely unfamiliar with the camera settings and assumed I'd done something wrong, but it's got a slide lock on it to change from manual to auto, and it's got a manual/AF switch on the side, plus a lock further up the lens again. It's a strange design compared to the lenses I'm used to (I use Canon normally).
