Originally posted by PeterDM Hi, I've been using Canon/Fuji but lately I've purchased into Nikon/Pentax - I've been loaded a 50mm 2.8 macro to use on the K3 while I decide on a lens kit - I'd appreciate suggestions for a three lens kit for travel - possibly a zoom, a macro and two primes. Any thoughts?
In the past I've travelled with a DA 16-45 and a DA 55-300, and once with an additional DA35 limited macro. The answer to your question depends a lot on what sort of photos you want to take - I like to photograph birds and animals, so I needed the long zoom. You also didn't mention how much you're prepared to spend, because that can make a big difference with some of the primes and zooms costing over $1K. I just bought a Tamron 17-50 f2.8 which I plan to use for travel, because ostensibly it has better IQ than the DA 16-45, but I'll have to wait and see! With respect to macro, the DA35 limited macro is a beautiful lens, but for the sort of subjects I find in Australia, the focal length is too short - if I'm photographing a bee or a wasp I really don't want to be that close to it, and with many flowers close to the ground, the short focal length means being on hands and knees. I think having the 100mm macro might alleviate some of these issues, but I can't really say because I haven't bought one. So if you are OK with having to be very close to your macro subjects, the DA 35 limited might work for you. The 35mm focal length also makes it a useful prime lens for other general subjects. The 100mm macro may be useful as a portrait lens. As for another prime, your choices will depend on what sort of subjects you're most likely to want to capture. I was considering a 40mm limited because it's small and light, and with the crop factor it's a reasonable compromise focal length. Another consideration is whether WR is important for you, because that narrows your choices considerably.
If you want to cover a wide focal range for a reasonable price I'd suggest:
1. If you want WR - the DA18-135 WR, DA 55-300 HD WR and DFA 100 WR macro
2. If WR isn't so important maybe Sigma 17-50 f2.8 or Tamron 17-50 f2.8 and DA 55-300 WR and DFA 100 WR macro or DA 35 limited macro.
I realise that's two zooms and one prime, but it's hard to cover a wide range of focal lengths otherwise. If you don't need the long zoom, you could replace it with another short prime or a wider zoom.
