Originally posted by atax112 Great tip zakewhipper! Thanks.
What should be my goal when trying out different settings? Should I look at the histogram ? Get an exposure around 0? Normally I adjust the three basic settings, keeping ISO at the lowest possible value depending on the conditions. Usually I am please with the overall quality of my photos, but sometimes I have some issues with blur. I am afraid to use fast shutter speeds and higher ISO settings as I don't want any noise.
I probably need to get more used to the great abilities of the K-30. I need more time to go through some tips and tricks around here.
So far I have noted framing and exposure. No idea how to begin
I will do some research.
You're welcome.
Your goal should be learning the pros and cons of how each setting change affects the image. The most important realization that you need to make and understand regarding photography is that it is almost -constant compromise- amoungst variables depending what your goal/s are with the photograph.
It's good that you try to keep the ISO low HOWEVER, don't obsess over noise. It is better to get -a- noisy photo than -no- clean photo. Remember, the principle purpose behind most photography is to capture and incident in time.
Your blur issues can be caused by...
...too slow a shutter speed to freeze the action.
...too slow a shutter speed for the focal length you are shooting at - even with image stabilization.
...poor camera handling technique.
...subject is out of focus.
...a dirty lens or lower quality filter.
...inconsistant performance of the lens, like at the extreme ends of the range of a zoom.
...shooting with the aperture wide open.
If you don't already have a tripod, get one and start using it. A lot of your blur issues will go away naturally, because a tripod allows you to use the full spectum of settings at any given time.
If I could figure out how to post it, I made a diagram once showing how to identify the nature/source of blur in photographs if one didn't already know.
When it comes to photography basics, and I mean those things that are not specifically digital technology related, any decent book on photography written since maybe the 1960's will be of use. Why, because the fundamentals of photography have not changed in nearly 100 years.
The series of videos put on by AdoramaTV on YouTube are great! They are short, well presented, and concise. I recommend them highly!
Here is an example:
